Status
Not open for further replies.
1 - 1 of 1 Posts
· Registered
This is a bad week! Two projectors with problems - maybe I should have taken a vacation.
Anyway, I just began to set up a VERY low hour XG-85 using a Dish 6000 HD receiver as a source with rgb. This XG has the new rgb/comp. input which I have not used vefore, but there was a field for "auto-detect" that I used on input entry. I used default data for entry and when the picture came up, it has a fast vertical roll. When the "info" screen came up, I noticed that the horizontal frequency was about 33khz. as I expected, but the vertical frequency showed about 32 hz. This is not what I always get with a 1080I source. Normally it is around 60 hz. Did I do something wrong on entry, or is there something wrong with the projector.
Many Thanks,
Bob
1 - 1 of 1 Posts
Status
