Status
Not open for further replies.
1 - 3 of 3 Posts
Discussion Starter #1
I am getting this "RANGE OVER" error
displayed on the screen when I try to adjust
edge focus.
I adjusted all the focus settings to the midpoint, but STILL
I get it.
I looked in the manual and it is not listed as one of the error codes.
Any ideas ?
XG1100
You can get a "Range over" error message when tweaking either Convergence or Edge Focus (or White Balance, but it's probably not that).
Note that all the settings interact such that the actual point that an adjustment becomes over range will vary for any particular setting. It's possible that some settings not to do with focus are causing the focus to go over range - if you see what I mean.
So check the other alignment settings for any unusually high ones.
As a check, copy to an unused memory and zero everything out. Then confirm that edge focus does work OK.
1 - 3 of 3 Posts
Status
