Hi!
I'm a little sceptical of WXGA resolution for watching DVD material. It seems to me that XGA would fit the native resolution of DVD better. DVD for PAL is 720x576 pixels (4:3). If anamorphic, that should be rescaled to 1024x576 on an XGA projector. That means no scaling artifacts vertically. On WXGA, it would be rescaled to 1366x768. Stretching 576 lines to 768 should blur the picture, right? Or does it really look better?
DVD for NTSC is 720x480 and doesn't fit as perfectly into XGA. Anamorphic would be 853x480 to avoid rescaling vertically. Black bars all around... maybe that's not possible to achieve, even with an HTPC.. http://www.avsforum.com/ubb/smile.gif
[This message has been edited by Viking2000 (edited 07-15-2001).]
