1 - 7 of 7 Posts
What are these little plugs for? They seem to be sized to fit in what I assume is the bass port on the speaker. Why would you install them?
Also, when I go above "65" on the Onkyo TX-SR313 they sound a bit muddy - is that normal? Any hints on what I should do?
(I'm actually replacing the TX-SR313 with a TX-NR414 because the main purpose of this is for poolside sound and I want iPhone remote control).
Discussion Starter · #3 ·
Yeah, that's the one. The manual doesn't mention anything about the plugs, as far as I can see.
if they are foam then they a probably port plugs. Should help you eliminate some of the muddiness of your speakers when inserted.
Banned
1 - 7 of 7 Posts
