Status
Not open for further replies.
1 - 4 of 4 Posts
I'm trying to find the 1365 x1024 setting on XP or powerstrip. All I can seam to find is 1360 x 760 or something... What's going, on I used to see it no problem when I had XP pro?
In fact it even had a setting that said (D-ILA)....?
Tryg,
I always use 1368x1024 so that you get the last 5 pixels on the D-ILA panel active. Copy the following PowerStrip settings
PowerStrip timing parameters:
1368x1024=1368,68,144,244,1024,17,3,16,145125,1
Generic timing details for 1368x1024:
HFP=68 HSW=144 HBP=244 kHz=80 VFP=17 VSW=3 VBP=16 Hz=75
Linux modeline parameters:
"1368x1024" 145.125 1368 1436 1580 1824 1024 1041 1044 1060 +hsync +vsync
and paste them in custom resolution set-up screen.
Discussion Starter · #3 ·
thank you. I'm haveing a hard time gettign the settings to stick. I set the custom resolutions then computer just restarts and goes to 800x600
Tryg,
The resolutions have to be multiples of 8 - so that's why 1360 and 1368 are your choices - not 1365.
Be sure you've rebooted the computer since the custom resolutions were chosen/defined - so that Powerstrip can
be sure the video driver accepts them.
Use the resolution slider in Powerstrip to choose the desired resolution. Powerstrip will change the resolution,
and also put up a dialog box that you have to click within 5 secs or Powerstrip will revert to the previous resolution.
If your video driver supports the resolution - it should "stick".
1 - 4 of 4 Posts
Status
