Status
Not open for further replies.
1 - 4 of 4 Posts
Just exactly what is the difference between the Auto1 and Auto2 settings on this Panasonic XP30?
Yes, I've heard that "Auto1" is the "recommended" setting, but I haven't been able to find any information on exactly what the differences in processing between two are, and I'd like to know.
I think it would be helpful to know what they do, exactly, if not just to satisfy my curiosity, but also so that the proper one can be selected in a manner a bit more scientific than "well I think this one looks better".
I assume the "video" mode is for deinterlacing standard 60field/sec NTSC signal... but "Auto1" and "Auto2" are rather mysterious labels and the manual is no help either.
Anyone know? Thanks!
"There are three deinterlacing modes on this player, but only two are worth using: Auto 1 and Auto 2. Auto 1 uses the FLI2200 to analyze the picture cadence and make decisions about film or video mode on the fly. However, the FLI2200 doesn't have a good NTSC 2-2 pulldown mode (used for 30 fps progressive material), so to improve the performance of 2-2 material, Panasonic added Auto 2, which forces the FLI2200 into film mode when it sees a 2-2 progressive flag pattern in the MPEG stream. There is also a video mode but strangely enough if you force it into video mode, DCDiâ„¢ is disabled.
Given the relative dearth of 2-2 titles in the US, Auto 2 is unlikely to add much value here. If you know that a particular title is 30 fps progressive, then it might be worth trying Auto 2, but in general we'd leave it on Auto 1. In Europe, however, 2-2 pulldown is very common, so Auto 2 might be a good default. The FLI2200 chip will auto-detect 2-2 pulldown if the source is PAL, so it might not be necessary to use Auto 2 even then. With Auto 2 the user should be watchful for combing artifacts, and switch to Auto 1 if they rear their head"
from the DVD shoot out
http://www.hometheaterhifi.com/cgi-b...deInt=0&mpeg=0
Discussion Starter · #4 ·
Interesting. Thanks guys!
1 - 4 of 4 Posts
Status
