I can get the best TV reception with an indoor Radio Shack double di-pole UHF antenna selling for $14.
I can get up to 98% with the UHF antenna. That number depends on how close you are to the transmitting tower.
With HDTV TV, you only need a signal slightly above 30% to get a perfect picture (at least that is the threshold number on my Sony TV) because HDTV are transmitted by using binary numbers (i.e. 1 or 0), so you don't need a strong signal to have a perfect picture.
I tried a couple other VHF channels and got the same max out of 41%. I found it kind of odd to get that same number so I was curious if that has any signifcance? |
