1 - 1 of 1 Posts
HI,
First i am sorry about my bad english...
I have a problem with streaming over Wired Lan, since i bought the Xtreamer.
i try to stream mkv files (720P/1080P 3GB-10GB) from PC with Windows 7 Ultimate + HaneWin NFS.
NFS settings on xtreamer are correct. (i can see the share folders ".nfs")
When i play some mkv file, after 30-40 minutes, the movie is freezing and if i try to press PLAY again, it stopped again. trying to play other files after freezing - same problem. only shuting down and restart the Xtreamer allow me to play the files again, until it freezing again.
I try to connect the PC to the Xtreamer via Cross cable (without router or hub) - and it happens again.
when i try to copy file (direct connection via cross cable) from PC to Xtreamer - i see that the speed it's only 4-5MB/sec. (while the speed between PC to PC is 10-12MByte/sec)
I realy don't know what can i do more.
Is it possible that i have a problem in my Xtreamer?
Maybe working Windows 7 with Xtreamer (linux) is the problem?
I try to copy files over FTP (Filemozila). i get a good speed (10-12MB/s) for 3-4 seconds and then Xtreamer is CRASHING and i must disconnect electric for restart and turn on.
Please help me
Shmulik
1 - 1 of 1 Posts
