Status
Not open for further replies.
1 - 10 of 10 Posts
Anyone wanna nominate some reception products for an unofficial "Yagi" award?
Categories include: Best Indoor Antenna, Best Outdoor Antenna, Antenna with Best WAF properties (Wife Acceptance Factor), best rotor, and best pre-amp. And how about Antenna with worst WAF property.
Some of my nominations:
Best Indoor Antenna:
Silver Sensor
Radio Shack Double Bow-Tie
Best Outdoor Antenna:
ChannelMaster 4248 http://www.channelmaster.com/layout_...%20Antenna.jpg
Winegard Model CA-8098 http://www.starkelectronic.com/wca8098.htm
Antenna with Best WAF properties (Wife Acceptance Factor):
SilverSensor http://www.winegard.com/products/vhf..._antennas.html
Of course, most of those funky looking Terk antennas don't work very well . . . basically, the best WAF antenna is any antenna you can get to work in your attic . . . be sure to look at those
Best rotor:
Channelmaster 9521A . . . it gives you another remote to play with! http://www.channelmaster.com/pages/rc1.htm
Best pre-amp:
The Winegard AP series, especially the Winegard AP-8275 http://www.winegard.com/products/acc...cessories.html
Channel Master Titan series: http://www.channelmaster.com/pages/ts1.htm
Antenna with worst WAF property:
Channel Master 4521 "Para-scope" http://www.channelmaster.com/pages/u1.htm
Just add a 50 foot tower and a rotor and blammo . . . instant divorce.
Channel Master 4228 http://www.channelmaster.com/layout_graphics/4228.jpg
It looks like your oven rack on a stick with some bow ties that are hanging out to dry.
Not 1, not 2, but 3 booms! It even has fins like a '60s Caddy!
Originally posted by Swampfox:
That oven rack really picks up UHF!
Imagine my wife's surprise when she went to use the oven and...
The button is labeled "Play", not "Pay". STOP the MPAA!
Our Silent Angels
Please visit The Manny Page!
Correction, you can roast 32s> weenies at one time!
Discussion Starter · #9 ·
Is it just me, or does there seem to be a direct correlation between how ugly an antenna is and how well it works? The uglier, the better it works. All those sleek stealth antennas don't work for crap. The Terk antennas seem to be famous for looking good but not performing well. (Personally, I haven't tried any but they don't seem worth the $.)
Let's see. If I take about 20 Terks and attach them to a wooden arrow about 5' long with points about 2' long each, now I'll have, effectively, a yagi design using attractive antennae. So, when approached by my wife about this contraption I can indicate that, by definition, it must be 20 times as attractive as just one!
Klunk!
Fade to black...
Our Silent Angels
1 - 10 of 10 Posts
Status
