Originally Posted by MichaelJHuman /forum/post/0
Changing the output to bitstream somehow outputs 48khz across HDMI? I would be skeptical of that, but I don't own one. You would want to make sure you are getting PCM over HDMI for TrueHD. The Yamaha display should tell you if its receiving PCM.
It's a well-known problem among A2 users who have HDMI receivers. I have a Pioneer Elite receiver, and changing the SPDIF setting toggles between 96 kHz PCM output and 48 kHz PCM output over HDMI. Unlike the A1, the 96 kHz ouput on this player is unacceptable.
Now of course I should expect PCM output from decoded audio, and nothing in this thread indicated otherwise. Unless you, like some others, are likening all PCM audio to 96 kHz audio, which is incorrect.
Also, just because 96 is a bigger number than 48, doesn't mean 96 kHz output is better for 48 kHz sound tracks.
Anyway, that's just the way it is; bad engineering on an issue that doesn't take rocket science to get right.
