1 - 6 of 6 Posts
Please advise!
I recently bought a HTR-5860 AV Receiver and set of JBL Northridge E80's, and EC35 center speaker to complete my system . While performing the Audio setup using the Auto feature and YPAO. The results keep returning a Warning W-1: Out of Phase for the Front L and Front R speakers. I have checked the connection several times and confirmed the connection is right. But, when I reverse the connection from (speaker + connected to receiver +) to (speaker - connected to receiver +) the system does not return the warning. And I know for a fact that the connection is reversed (not correct).
Note: in the Owners manual, they list the cause for this as:
Speaker polarity is not correct. This message may appear depending on the
speakers even when the speakers are connected correctly.
Is there an explanation for this? Should I keep my receiver / speaker connected correctly and forget the warning? I am afraid if I keep it reversed it will eventually cause problems with the components. Any suggestions?
Discussion Starter · #3 ·
Thanks jeffK987
I searched many forums here and can't find a single item about this. Has anyone else run into this issue? Can anyone point me to the forum that mentioned this? Do you think I should call Yamaha support, and do you think they could advise?
Originally Posted by kicks95
Please advise!
Speakers out of polarity will only cause problems w/ quality of sound, not physical problems with the system.
1 - 6 of 6 Posts
