I have been using the Yamaha AV Controller app on my iPad and iPhone since nearly day one of launch. I have the RX-V3900 receiver. Everything has been working flawlessly until last week. Midway through watching a movie, zone 2 turned on, then the volume turned up, receiver turned off, then on, then switched to tuner, changed stations etc. Totally random changes. I am on a 100% secure home network and I had in my hands the only two devices which control the system. I have since had to unplug the ethernet cable from the receiver as I cannot trust it to not turn itself on and crank the volume (I had previously set max volumes thank goodness or my speakers would be toast). This happened multiple times and it is completly random - I cannot dupplicate the problem, it just happens on its own.
I am wondering if anyone else has experianced this issue? If so have you solved the problem?
I hate to let this go on since it also controls the zone 2 which is my pool speakers outdoors - not sure the neighbours would appreciate blaring music in the middle of the night!
Thanks in advance,
Scott.
Thanks in advance,
Scott.
