Status
Not open for further replies.
1 - 1 of 1 Posts
Discussion Starter #1
Yesterday after I turned off my HDTV cable box and turned it back on again I no longer get audio. I plugged it directly into the TV to make sure it wasn't the box and I do get audio from every channel from the internal TV speakers. However, when I go through the reciever (using Optical Audio Cable) I only get audio from the analog stations and not any of the digital ones or the HDTV ones. I have checked all input settings and everything seems to be correct but I'm just not gettting any audio. Thanks for the time!
1 - 1 of 1 Posts
Status
