yamaha htr problem
727 Views 10 Replies 3 Participants Last post by  steve05Ser
Well i just recently had my yamaha HTR-5890 receiver start to act up on me.
Now it is plugged into a surge protector(not a cheap on either) and i even tried plugging it straight into the wall. But the reciever turns on and after about 3 seconds of loading its stuff up as normal just shuts off. I have unplugged all wires from the back except the power.
I tired the let it sit unplugged to reset and that didnt help. Any tips on how to trouble shoot this?
I could take it into yamaha service but its 75 bucks right off the bat. And i have a feeling it will go more. So im getting to the point where i dont want to spend more on a older one when it costs the same as a new one with warrenty.
But i do love this receiver and dont need anything more than what it is.
1 - 11 of 11 Posts
Take your pick of what interests you here and forget about fixing your current htr. Its most likely not worth fixing unless its a very cheap part - and like you said you'll be into it for $75 before buying any parts.
Well i would only want a reciever that is very compariable to this one.
My needs- the 140x7 watts, im running JBL venue stadium speakers so it has to be pumping out the juice.
Things i dont care about- I dont need it to have hdmi inputs/outputs. I send all signals to the reciver with optical. I dont need the sat radio crap. All i see in the same power range is about 900+ dollars. Im not seeing anything comparable for the price i paid (about 450)
I doubt you really need 140wpc in a receiver. The JBL Venues are 91db efficient and 8 ohms. Not a difficult load for any decent receiver unless you are playing them way too loud or in a huge room.
Most any decent receiver should be able to drive them with no problem.
Don't let power steer your judgment to what you want or need. I don't think you'd be able to tell the difference between a 5 channel receiver with 50wpc and one with 150wpc.
It only takes 1 watt to make 91db worth the sound/music/noise with your speakers at 1 meter. To double the sound level it takes 10 times more power - 10 watts. From 10 watts doubling the sound level takes another 10 times the power. So the difference between 50 and 150 watts isn't as wide a gulf as it would seem. Less than 3db at full volume and not measurable by the human ear...most anyways.
See less See more
Well thats the thing i like to have my movies/music cranked for long periods of time. And my house im getting next year will have a big living room.
I know im being picky, but i dont want to run into distortion nor a reciever that gets very hot from being palyed at max. Thats what i liked about this one, could play it hard and it not get hot or get distorted.
I appreciate the help tho, thank you
In other words - I was no help whatsoever?
To double the sound level of your old AVR would take 1400 watts per channel. As I said - I doubt you'll hear much difference between 50 and 150 watts per channel.
See less See more
No you were a help lol. I just checked out that i paid 445 shipped for it 3 years ago. Im just being iffy about getting a new one if the 75 dollar repair could fix it. Cause they said they fix the circuit boards, not just order a big new expensive one.
Something to consider might be a newer AVR like the
HK 347/354 - Onkyo 606 or 706 - a Marantz 6001 or 7002 .
All are covered by manufacturers warranty and they should power your speakers just fine. If not - get an external amp!
Any of those would be better than buying used with no warranty.
Addressing your power needs - you might read this article .
See less See more
No way does that thing put out anywhere close to 140W*7.
edit -- at 40lbs, though, it'll come a lot closer than current Yamahas
I looked at the specs - it puts out over 800 watts total. Doesn't mean it puts out 140wpc - but I agree - it probably does better than the newer ones.
Yeah i have decided to get it fixed, im just not ready to part with it yet.
Im not saying its the best or anything, but i really do like it. And The way its acting up i feel it just got shocked or something, even tho its on a good power strip. The isnt really anything new that interests me enough.
But yes you have helped me make my desicion, so i thank you
See less See more
1 - 11 of 11 Posts
