Status
Not open for further replies.
1 - 2 of 2 Posts
I just picked up one of these for $150 for a bedroom HT setup. Does anyone know if it will produce good results using some NHT SuperOne's (fronts) and SuperZero (center)? I can get a good deal on the NHT speakers. I can return the receiver still. Are there any good alternatives for a receiver to drive these speakers?
I'm running a 5550 with Thiel main speakers and it works fine. BUT, I don't crank it up real loud. If you do the same, I think you'll be fine. But if you want to try to shake the room, I'd move to something bigger...
1 - 2 of 2 Posts
Status
