I presume you mean composite input, not component input, as AV4 is a composite input? Just had a look through the manual, and it says very little about composite video resolution/compatibility problems? There is a bit of info on pages 46 and 143, but, apart from that, there seems to be little that will be able to assist you. I'm sure others will be able to give you some better advice than I can. Good luck.
