1 - 1 of 1 Posts
There has been a sudden loss of output to the main/front speakers which are driven by an external amp the signal of which comes from the Pre-Out. The external amp is fine, and the receiver is otherwise OK. If have the receiver set itself up automatically using the microphone, it has to increase the output to the main/front speakers by the max (10db) and decrease the surround and center speakers by the max (10 db) but then the mains are bass-heavy and muddy and still the output is low. Previously everything worked fine and all speakers balanced out to within 2 db of each other.
I cannot correct this with any of the settings. Is this a setup issue or does this represent a component failure?
1 - 1 of 1 Posts
