1 - 7 of 7 Posts
Dear All
I am having problems with my sisters' home cinema set up which has failed in recent months.
(The Panasonic had to go away for repair as the PSU failed.)
The setup is:
Panasonic 50" plasma
Pioneer Blue Ray player
Virgin Media Cable TV set top box
Yamaha RX-V465
I am using HDMI cables to link everything together.
Before upgrading the firmware on the RX-V465 nothing was really working (it did once when originally setup)
After upgrading the firmware to the latest available - sound started to work from both sources (HDMI for BD, HDMI2 for CableTV) and switching between sources was good.
I cannot understand why I am not getting any video through from any of the sources even if I change the output resolution on the BD.
Can someone please tell what is going wrong or if there is a know problem which requires a warranty fix of the RX-V465.
Both source work when directly cabled to the Panasonic.
Thanks very much in advance.
Discussion Starter · #3 ·
Hi There - thanksfor your response.
What I am saying is that after a number of events i.e. the Panasonic having to go away for repair and the system not being used for a number of months etc.... on reconnecting everything I am unable to switch and receive any video on the TV.
I was looking for a reset to factory default and found the firmware update available which I believe resets everything in anycase.
Now I can switch sources and receive only audio from each.
Discussion Starter · #5 ·
Thanks for your reply - do you know the procedure to 'Reset the Microprocessor' as there is nothing on Reset in the manual.
Discussion Starter · #7 ·
Spoken to Yamaha....they have said to try and reset the unit - process is under Advanced Setup!
1 Press STANDBY/ON to set the unit to the standby mode.
2 Press and hold TONE CONTROL and then press STANDBY/ON to turn on the unit.
The unit turns on, and the advanced setup menu appears in the front panel display.
3 Press PROGRAM left / right to select the parameter you want to adjust.
The name of the selected parameter appears in the front panel display.
4 Press STRAIGHT repeatedly to change the selected parameter setting.
5 Press STANDBY/ON to confirm your selection and set the unit to the standby mode.
We need to select Initializing:
Initializing INIT.
Use this feature to reset all the parameters of the unit to the initial factory settings (see page 80).
Choices: CANCEL, RESET
• Select “CANCEL” not to reset any parameters of the unit.
• Select “RESET” to reset the parameters of the unit.
Apparantly the volume will display -40db if the reset is succesful.
I will try this in the day or so and let you know.
1 - 7 of 7 Posts
