1 - 1 of 1 Posts
Hello all. I just bought the Rx-v 773 that is set up as 5.1 system. I'm using the Klipsch SP-1 with built-in sub as front speakers, and are set as large. The Klipsch LFE is connected to Sub 1 on the receiver. The Rx-v 773 has connection for pre out, sub 1 and 2 (sub 1 has been used for the Klipsch).
Now, I want to add my old speakers (JBL S26II bookshelf) for Zone2, which will be connected using the EX Sp/Presence section. I also want to add the Polk PSW505 sub to power the Zone2. The Polk sub has connection for LFE, Line in, and high level (speaker wire) connection. Please tell me in lay man's language how to make this connection. The system is working fine now with the current set up. I just want to add the sub for Zone2 (or to split the second sub to the main and Zone 2) . Thanks you.
1 - 1 of 1 Posts
