I have not been able to control my RXV1 using the wired IR Remote inputs on the back of the receiver. I called Yamaha Technical Support who said that either Remote 1 or Remote 2 should work. I have the correct cable and have confirmed that this cable will light a IR led.
Have any of you successfully controlled a Yamaha receiver via its wired IR input?. If so what IR equipment did you use?
Derek
Derek
