Status
Not open for further replies.
1 - 3 of 3 Posts
Banned
I have both of these recievers sitting in my home and I am having a tough time deciding which one should I keep. Yamaha does tend to sound a little bright for music but really good for HT whereas Pioneer Elite sounds really good for music and Ht but seems to be less powerful than Yamaha and it's remote isn't quite learning capable. I am not able to decide which one I should keep. Please suggest.
I have hooked them up with JBL speakers.
I think you can answer your own question.
Based on what you told us, get the Yammy if you will be doing mostly HT and get the Pio plus a better remote if you will be mostly listening to music.
Bill
Banned
Discussion Starter · #3 ·
I listen 50/50 HT and music. The pio remote is the one I am having problems with learning other components. Thanks for the reply though.
1 - 3 of 3 Posts
Status
