Did you just call a 10" sub a "larger" sub?
Meh.Minimum RMS Output Power for Subwoofer
30Hz, 6Ω...........................................................120W
As a music lover (see sig), I've moved to pro tour grade drivers in my subs. There isn't a comparison between some cheap Chinese 10" driver in Yamaha's subs and the 21" Italian made B&C drivers companies like PSA use.
I haven't used a 10" subwoofer since the late 1990s. Hell, my mains in the theater have dual 10" drivers while there are four 18" and two 21"s with ~15k watts of amplification. Even the La Scala IIs in my 2 channel system have 15" folded horn bassbins.
From one musician to another: You need to get out more and experience more subs. Even among cheap subs, this isn't a great option and the fact that it is passive means most will also have to invest in an amp to power it, so any cost advantage quickly evaporates.
Even in pro gear, Yamaha is not a good company for subs. I cringe when I see them as it often means the B string is neutered.
What are your physical space limitations and budget limitations? An SW-P3600 + outboard amp may not be the "best components" to suit them. E.g.:... Not everyone's wallet is big enough to spend over $1K just on a sub alone ... But a smaller wallet and smaller physical space limitations don't make anyone less of an enthusiast than you. We just pick the best components within our physical space limitations and our budget limitations.
Well, we tried. They are addicted to the Yamaha koolaid. There is no helping here.
OP, it has nothing to do with cost. It's about ability and Yamaha is so low on that scale it's never recommended. There are too many other better performing brands.
That is true. There are worse brands. 😘Better than being addicted to the Bose koolaid--😊. At least Yamaha uses larger drivers capible of lower frequency reproduction at a more natural level. Bose uses smaller drivers and electronicly boosts/emphasizes the lower frequencies they can produce to give a false impression of good bass.
I fully understand; the Klipsch La Scala IIs alone were $8k, never mind the Parasounds, etc in that system.I deeply respect those who are fortunate enough to take things to a higher level than I can. Wouldn't a 21" sub cost over $1K? Not everyone's wallet is big enough to spend over $1K just on a sub alone, or any speaker alone for that matter. Also, not everyone has the physical space for some of the speakers you described. But a smaller wallet and smaller physical space limitations don't make anyone less of an enthusiast than you. We just pick the best components within our physical space limitations and our budget limitations.
At any rate, welcome to the forum. Be careful and forewarned, reading most anything here will make you burn cash. There's TONS of information and some extremely knowledgeable people here who will be more than willing you help you navigate all your A/V needs.
