Hi All,
I have a Yamaha V2400 and have a question about the on-screen display through the component jacks.
I'm playing 1080i HDTV and routing through the 2400 to a projector. I have the setup of the 2400 set so that it is supposed to route the OSD through the component video montitor out jacks when using the setup menu. However, this does not appear to be functioning and I cannot access the setup menu w/o using the S-Video path to my projector.
Has anyone else experienced similar? Is this related to the 1080i source info (ie might it work in 720p/480p)?
As a second part of this - any clue WHY it appears that the unit will not also output the Volume level through Component when changing volume, like it does through the S-Video outputs?
-Jim
-Jim
