1 - 4 of 4 Posts
hello all,
Yamaha V663
i am trying to hook up an audiosource 2 channel amp to run some polk in wall speakers in the other rooms.
so far i only can have the zone 2 source feed from the tuner and nothing else, i need it to get info from catv, dvd , dock.
i tried all combos i think of using preouts, zone 2 outs, and extra sp settings.
its driving me crazy, i just spent all morn running wire and installing speakers.
one set of speakers work if they are connected to "B" speaker.
Please help, i am going to lose it....
Banned
You need to use both analog and digital inputs for each of your sources. Zone 2 does not have DACs (digital to analog converters). This is common in most receivers so it is not just Yamaha.
Bob
Discussion Starter · #3 ·
Then how does one hook up to more than 2 ouptuts??
if i run an audio out from fios tv to rca input on recvr. would that override audio on an hdmi connection?
Banned
No it wouldn't. The second zone only looks for the analog inputs. The main area can still be HDMI, toslink or coax.
Bob
1 - 4 of 4 Posts
