No, the wire gauge should have nothing to do with it shutting down. Recheck your wiring, make sure the wires are not reversed, - going to - and + going to +. If that doesn't help I would start over completly conneting 1 speaker at a time and then trying it in between each speaker connection. You might have a thin strand that you can't see that is shorting out somewhere.
