Yamaha YPAO Mic Replacement
31285 Views 11 Replies 7 Participants Last post by  Gordon Bombay
I bought a used 663 and I'm now in need of the YPAO mic. I've got everything calibrated distance/frequency and all that other stuff but I figure running the YPAO setup will probably yield better results. ??? Maybe? Anyways, I haven't been able to find one for under $50 which seems a little steep for something that tiny and that i'll only use once or twice. Basically what I'm trying to ask is, does it really help to use the YPAO setup and then adjust what may be off? Does it give a better sound quality than just playing it by ear and adjusting the normal settings in the AVR?
I think I might just go to BB and buy a Yammy AVR and use the mic and then take the thing back.
See less See more
1 - 12 of 12 Posts
For more Replies..
Try posting here:
http://www.avsforum.com/avs-vb/showthread.php?t=995796
The mics are calibrated for each model, not interchangeable. Whether you buy one is up to you. Is the prospect of a 7-ch parametric EQ for each speaker worth-while? Unless your speakers are all identical and in identical placements, the benefits could be considerable, but that's ultimately in the ear of the listener.
Some day all those missing mics will turn up.
See less See more
I had a Yamaha RX-V465, and now have bought Yamaha RX-V471. I've managed to confuse the two cables, the cable is to connect and set the sound YPAO ... What I wonder is whether this cable is exactly identical on both models, so it does not matter which I use of them new RX-V471 to set the sound? They look almost identical, except that one is a little bit wider "opening" on the widget a set where one should sit ... hope someone can answer this?
This is funny, just stumbled upon your thread. I just bought an open-box RX-V471 from BB yesterday and it did not have the YPAO mic. I asked them if they had one in the back (I used to work at BB a long time ago, I KNOW they have tubs of the accessories from floor models in the back) and the guy flat out told me no we throw them out which is BS.
So now I'm scouring the internets to find the part number for this specific receivers YPAO mic. I emailed Yamaha asking for p#, if I hear back from them I'll let you know, if you figure out in the meantime I'd appreciate if you could inform me!
According to this page the same part number was supplied for both your units. I disagree with the previous commenter, and not every model has its own unique mic, although there are a few different models out there of the mic. Don't know why yours would be slightly different other than changes in manufacturing process.
Now that's settled, wanna sell me one of your cheap?
See less See more
Where do you see RX-V471 on this list you linked to?
Here's the part number, via Yamaha support, wn649600
. Didn't ask specifics on whether or not the mics are differ between models (figure regular support wouldn't really be informed with info like that). Hopefully this is what you needed as well.
See less See more
Does anyone have this wn649600 mic, and can tell me how many mm is the mic in the middle? This is the one for rx-v465? I have to know exactly mm, so I can tell it apart from the one I have for RX-V471. Can anyone confirm the ypao mic used for RX-V471 is exactly the same as the one for RX-V465? I can not find info about it anywhere...to me one of the ypao mics looks a little bit bigger than the other...
Right below RX-V467 and right above RX-V563.
In the link I previously included, it lists both the RX-V465 (&RX-V465BL) and, two more items down, the RX-V471. So the same part should work for both.
I suspect any difference is just a change in manufacturing.
Have you tried them both? I'd think you shan't be able to tell the difference between the two results.
(Now that I've cleared this up for for, feel free to gift me your extra unit.
See less See more
ousooner2, did you ever get your hands on that YPAO mic? I am in the same boat with my. Yamaha RX-V471 receiver.
1 - 12 of 12 Posts
