Hi,
I am not sure if this post is in the correct forum or not. Here's the problem I am having.
I have my HTPC connected to the VGA input (PC input) of RCA MM52100 RPTV. All the three tubes were burnt due to power spike and RCA took about six months to replace them. Now I have it fixed. The problem is, that the picture ghosts in the left side of the screen. About 20% of the screen from the left side top to bottom has a yellow tinge of ghosting. I do not observe this ghosting or yellow patches while watcing video or any other source. (Maybe the problem exists in the other source inputs too but I cannot tell it.)
I am supspecting if the technician, who I believe is looking at the innards of an HDTV for the first time, did not align something right; like the mirror or the tubes themselves.
I have tried auto-converging many times but it did not help.
You can see in the attached pictures the yellow ghosting to the left of the screen.
You can see larger pictures here
Yellow Ghosting in Icons - 479KB
Yellow Ghosting in Text - 345KB
I would appreciate any help.
I am using GeForce2 DDR (Asus 6800 Deluxe). Windows XP. I am using Asus Windows XP driver. The display is at 800x600 at 60hz (only resolution supported by the monitor in the VGA port).
