I am contemplating a ceiling mount for a Z2 and for convenience, will mount the projector in front of the seating area.
The mount would be 11.5 feet front the screen, and the "prime seat" would be about 13-14 feet from screen.
I was concerned that the unit would not respond to the remote control, if the sensor was not in line of sight with the remote.
Is this really a problem? If so, any ideas how to correct it? I would not want to cut power to the unit with a switch, as I guess it still needs power for the fan to cool off.
I guess I could just get up...but not as elegant. I could also run one of those IR extender things (like hot link pro ) to my electrical closet, but I am not sure if it is long enough---is see this as an option, but would likt any other ideas.
Pierre
Pierre
