yes and also extras.. Won't play Anything..Is anybody having problems playing trailers?
I have nearly the same: after 50 - 60 mins, the image jerks for 3 secons or is completely green.image jirky
154/5000
hello ... I'm running on zappiti 4k hdr mini last fw
the problem is with 1080p movies (mkv, m2ts) every 10 minutes the image jerks for about 3 seconds/ the 4k movies are ok
i try this settings
Dynamic Range: Limitted (Settings / Display)
Deep Color: 10-Bit (Settings / Developer Options)
Color Space: Y'CbCr 4:4:4 (Settings / Developer Options)
These settings guarantee perfect shades in HDR gradients and a perfectly smooth picture on 23.976p HDR movies. Finally, these settings correct the problem of blacks gray on MKV encoded in HDR.
Since firmware version 3.15, the following settings can be used:
Dynamic range: Limited (Settings / Display)
Deep Color: Auto (Settings / Display) >> WARNING! On some TV, Auto mode ca generate some issues.
but nothing
Has anyone happened to that?
Depends what you want to doQuestion here about Zapitti One SE HDR.
I've acquired my Zapitti about a month ago but until today I can't figure it out why device is not visible on local network. Windows 10 on my computer seem to be configured correctly since it can see my other networked devices including 2 NAS boxes. I have been trying to get help from product support but it is slow process and so far no luck. I've reseted device, restored firmware on OpenWRT. Still nothing. I'm not very familiar with Open WRT but seems that my Guest,WAN and LAN are not connected. Could someone help me and provide a screenshots or ideas to figure out which network settings need to be changed?
I don't use an internal drivehi all, i am looking at getting a zappiti player but a bit confused on which one to get and what hdd options and connectivity method to use. i am planningn to burn some of my blu rays to a hdd.
after that is there a way i can just plug my hdd into my router and will the zappiti mini see it?
or do i have to splurge for the more expensive one and just plug my hdd in via usb ? is there any benefit doing that vs using an internal hdd inside the zappiti?
Thanks. That doe's not workDepends what you want to do
A couple of suggestions that work for me
download the windows Zappiti Video app, and if the player is switched on you should be able to access the player
use file explorer and type \\zappitiHDR and you should then find the drives connected to your zappiti
Enabled SMB 1 on windows 10?Thanks. That doe's not work
yes,it is.I have 2 NAS boxes visible on network but not zapittiEnabled SMB 1 on windows 10?
I am in the same boat. It used to work fine, then I moved, and since then I can't see it on my network.yes,it is.I have 2 NAS boxes visible on network but not zapitti
1) Yes, you can do this. I replaced my Popcorn with a Zappiti. The Zappiti expects separate movie and tv shared folders, and a specific naming format "movie name (year) (...optional stuff).ext" "tv show name S01E01.ext". Or you can get a NAS. You don't need a disk in or attached to the Zappiti to use it, but you can put one there.Hi,
I'm looking at replacing my ageing Popcorn Hour box with a new media streamer and I'm considering a Zappiti device (probably a One or a Pro) and I just have a couple of questions:
1) Can I run the Zappiti without any internal storage and just stream from my existing media server (Windows box on a wired, gigabit network)? Or does it require at least some internal storage?
2) If I'm running the Zappiti like that, can I use the "Video" application on the Zappiti (and the iPad app) to browse the titles stored on my server with artwork etc. I read something that suggested that networked storage could only be accessed by the "Explorer" app, but I may have misread it?
3) The main difference between the One and the Pro seems to be the build quality and quality of components etc. and therefore hopefully higher quality output from the pro. Are there any other differences I should be aware of?
4) Is there anything else people think it would be worth me knowing before going for the Zappiti? Any gotchas or issues to be aware of etc.?
Thank.
1) Yes. I have all my movies stored on a separate Windows 10 media server. Main issue is you still need to allow SMB1 on the Windows 10 box which is a security issue.Hi,
Thank.
I guess verify if you need a new device now or if you can wait for the next gen players to come out, as the chipsets in the current models are dated and will be replaced soon (supposed to have been last year). And if using a Synology, beware they have recently planned to retire SMB1 which Zappiti requires, though the decision has been postponed it's not likely to be longterm, so if you use a NAS or rely on SMB, maybe they'll have SMB 2 or 3 support in next gen players. Using a Synology NAS requires Mono, which Synology plans to phase out too at some point.4) Is there anything else people think it would be worth me knowing before going for the Zappiti? Any gotchas or issues to be aware of etc.?
Thank.
