Status
Not open for further replies.
1 - 3 of 3 Posts
There was a brief power outage recently and now my Zenith 1080I is not working. After unplugging and then replugging a red blinking light goes on and then after a few minutes changes to green. It then says scannng for channels and after a while says scan unsuccessfull. The on off swith does not work anymore, the unit can not be powered on or off. Is there a reset switch somewhere inside the chassis? Is the unit kaput?
Thanks for any advice.
Discussion Starter · #2 ·
Sorry,
I meant the Zenith SAT 520
Leave it unplugged for a couple hours, that'll reset it, if that doesn't work, something is probably cooked in it...
1 - 3 of 3 Posts
Status
