Status
Not open for further replies.
1 - 5 of 5 Posts
A friend of mine is having trouble making adjustments to my Zenith C34W23 set. If he attempts to access the TV?s menus directly - the TV powers itself off. Somebody told him that it sounded like a finicky power supply.
I understand that the tech. set-up menu may be helpful. The only menu setting he has access to is the cable box (Cablevision HD IO). Has anyone had experience with this? Thank You in advance...
How are you accessing the service menu? I have experience with the menu, so if you can get into it, I may be able to help.
I'm assuming you're using the following to get into the menu:
1. TV turned on
2. Press and hold the 'Menu' button until the Channel/Time display appears
3. Press 9-8-7-6 then 'Enter'.
1 - 5 of 5 Posts
Status
