Status
Not open for further replies.
1 - 5 of 5 Posts
As far as fringe area reception it's the best I tested and I tested them all. I get PSIP info from it at all. There might be a reason for this I haven't found yet.
DVW
I had my HDV420 for almost 30 days.
not sure if I should keep it or not.
the unit itself works.
live SW in Chicago and it get greats signal reception.
use an outside Winegard 7080 ant.
just wondering if certain features would be nice like: PSIP and output both 1080i and 480i at the same time
also, the CC does not work on any channels at all.
either this unit is ahead of the CC that all the stations are outputting or something is not right.
the main reason I might return it is there really is not much of my interest that is HD. I know the DTV channles come in better than the NTSC analog ones but hey, its only TV. Who cares about a sitcom in HD or DTV.
It is a little furstrating when a DTV channel is in a 4:3 format and one cannot change the aspect ratio.
1 - 5 of 5 Posts
Status
