801 - 820 of 830 Posts
I played an MP4 with an AAC soundtrack last night and the volume was so low I could barely hear it. Play same file on my Intel NUC mini PC and volume fine. Any thoughts? Playing both through my Denon A/V receiver over HDMI.
make sure zidoo volume is full blast..
use the zidoo remote and turn up volume to max..
this won't affect hd audio but does affect pcm and aac etc.
Epson 5040UB projector, Denon 6300, 7.1.4 setup, M&K THX speakers and SVS subwoofer
Thank you, fixed it.
Is it possible to install Kodi on the Z9X but retain Dolby Vision playback functionality? I bought it because the DV support is more extensive than on the Shield but large portions of my TV shows are unmatched (formatted in a way that kodi had no issues with) and I'm thinking now of just returning it and sticking with a Kodi device.
EDIT: I found a way to rename my TV collection easily, does anyone know what naming scheme the HT 4.0 scraper requires for a successful match of a TV show?
Beta version v6.3.12 for Z9X/Z10 Pro/Z1000 Pro/UHD3000 released
System
1. Optimized system stability.
2. Added "Play Selection Time" function for colorful shortcut key.
3. Optimized the long press function for remote control.
4. Optimized audio and video synchronization and response speed for Dolby Vision files after fast-forward.
5. Added the support for a variety of Dolby Vision formats as below:
BDMV/ISO:
Direct playback, P4/P7 MEL/FEL, dual track
Blu-ray menu, P4/P7 MEL/FEL, dual track
M2TS/TS:
P4/P5/P7/P8 MEL/FEL, single track, dual track
MKV:
MP4:
Player
1. Added the function of skipping title and cast for TV series.
2. Added time selection shortcut key.
3. Fixed the problem that subtitles cannot be turned off by default.
4. Added title display for MKV subtitle.
5. Optimized playback stability.
6. Optimized more information for movies and display DV content.
7. Optimize 3D menus playback.
8. Optimized the problem that audio and video are out of sync for Dolby Vision after fast-forward.
9. Optimized subtitle download.
Music player
1. Fixed the problem that DSD format bit depth was wrong.
2. Optimized the disorder code problem of several audio files.
3. Optimized the speed and accuracy for searching lyrics.
4. Optimized lyrics parsing.
5. Modified a part of the translation.
6. Optimized the singer picture interface.
7. Optimized the stability of music data parsing.
8. Optimized data acquisition on cell phone app.
9. Optimized the acquisition of local album pictures.
10. Fixed the problem that song data is not removed when storage device is removed after suspending scanning.
11. Fixed the problem that the details interface does not refresh after modifying the singer's picture.
12. Optimized playback stability.
13. Added the function to change the artist and album cover manually.
14. Optimized the background display of the playback details interface.
15. Optimized the display of album pictures.
Poster wall
1. Fixed the problem that TVmaze cannot manually modify the poster.
2. Added clearlogo for TV series.
3. Fixed the problem that the poster background of certain TV series cannot be changed.
4. Optimized the problem that posters from Douban cannot be obtained.
5. Optimized application stability.
6. Optimized the matching accuracy of animation.
7. Optimized the display of poster replacement interface.
8. Modified a part of language translations.
9. Optimized TMDB matching accuracy.
10. Optimized the acquisition of trailers.
11. Fixed the issue that the trailer cannot be matched in Traditional Chinese.
12. Optimized NFO episode matching.
13. Fixed the problem of incorrect recognition of several TMDB animation.
14. Added Rotten Tomatoes score display.
15. Added the function of skipping film title and cast.
16. Added the function to play film and enter the detailed settings when clicking posters.
17. Fixed the problem that the movie will automatically skip to the end of the movie when replaying.
18. Optimized the details interface display.
19. Added PLAY button in listing interface.
20. Fixed the problem that there is no sound in trailer occasionally.
21. Added selling points in details interface.
Premium Member
I don't believe I see a fix listed for the HT4 trailers no longer working?
the work with this as well as the hot fix ht 4.0 apk mirror released. 4.067 HT but to answer the q. yes it works correctly now. audio and video.
Sent from my SM-G965U using Tapatalk
Can I use the Z9x AV output for connecting audio only to a Monitor (-speaker) controller or to the Red/White RCA inputs of my computer soundcard. The TV has the Red/White audio outputs also, so which is best to use (or doesn't it make any difference? Maybe somebody has already done this and spare me some additional thinking :unsure:...(Still catching up on Pro Vision and Z9x threads and all related issues...)
Thanks for the info, but I downloaded the latest 4.0.69 HT 4 apk and installed on my Z9s and still no trailers will play.. everything else in Home Theater works fine...Will I need an actual firmware update for my Z9s as well?
So, 4.0.67 did allow trailers to work??... and 4.0.69 does not work now?
New
Ok guys dont know if this is the right place for my question but here it goes:
I have a denon 4400h and output to my philips 70pus7304 4k tv and my optoma hd131x 1080p projector. On the denon i have connected my ps4 pro, a sony x700 player and my zidoo z9x. The thing is i have picture on my projector from my other sources but not from the zidoo. Any ideas why this is happening? Thanks in advance.
JVC NX7 Projector, Draper 132" (2.35:1) Techvision XT 1300x, Panasonic DP-UB420, Zidoo Z9x, Zappit
Are you trying to display the image on both the flat panel and the projector at the same time? If so, try to connect the Zidoo to each display alone. If the image displays properly, the problem is likely a mismatch between the acceptable resolution of the 2 displays (i.e. 1080p vs 4k).
If the above is not what you are trying to do, start basic troubleshooting: run an HDMI cable from the Zidoo directly to each display, one at a time. (bypass the Denon AVR). If you see the image on each display use the same HDMI cable, run it from the Zidoo to the Denon and try again. If no image appears, check the Denon's video settings. If you have a "pass through" video setting on the Denon, try that. You can also try different HDMI cables to determine if the cable is the problem. Troubleshooting means disconnecting each piece of gear and reconnecting until you find the component that isn't properly passing the signal. Good luck.
No im trying to display the image only on my projector to watch a 3d movie and have selected monitor 2 on denon. It worked last time i tried several months ago, could the problem appear after a zidoo firmware update???
Anyone else have issues with their Z9X freezing? Mine got stuck at some point last night and I couldn't get a signal today until I powercycled, the red LED at the front was blinking too.
