Status
Not open for further replies.
1 - 4 of 4 Posts
I tried to run the THX audio tests found on the Monsters Inc. THX setup menu.
The first test that plays noise through each of the speakers works fine. When I tried to run the in-phase/out-of-phase test, zoom hangs. I tried with my initial graph of ffdshow, reclock and ac3filter, then tried default waveout. Both settings hang at the same place.
I am using a sound blaster live value spdiff out to my reciever.
Has anyone gotten this test to work via zoom with any graph?
EDIT: I am using the Sonic Cinemaster v1.5 audio decoder.
thanks,
Discussion Starter · #2 ·
^bump
Anyone successfully run the THX "in phase - out phase" sound tests with zoom?
thanks
Discussion Starter · #4 ·
OK, that is good to know. I will change out the Sonic audio filter and try others.
thanks,
1 - 4 of 4 Posts
Status
