1 - 4 of 4 Posts
· Registered
I've this problem with my zoom player and ffdshow. I can't use queued sample because ffdshow set off this option. it say "off, the video renderer is use is not supported".
i've a piv4 3.0 ghz, an ati 9600 pro under xp home or xp pro.
any idea?
thansk a lot.
· Registered
Are you using vmr9 ?
If you use overlay is the problem still there.
The queue is a bit of a speed boost, but it's not nessessary.
· Registered
Discussion Starter · #3 ·
no. i'm using overlay on a Panasonic plasma 37pv60. Also I tried vmr9 (windows, windowsless, and without rendering) but doesn't work.
I've an hyperthreading cpu maybe the queued option is important.
thanks.
· Registered
'Queue output samples' was built for dual core cpu's.
Not hyper threading cpu's.
It might not even help hyper threading cpu's, the coder who built it isn't sure.
1 - 4 of 4 Posts
