Ok, I got a radeon card.
I don't know why, but part of the overlay code seems broken. I can set the overlay color controls, but for some reason, I can't get their current settings. But I guess this is irrelavent.
I'm currently in the process of adding the code to allow setting the overlay color controls.
In my inital testing, I found this settings to be "weird", not really what I expected, but then again, I'm not the expert. I'm going to set this as edit fields which you can basically input any number and experiment with the result.
Ok, about the radeon card itself, here are my first impressions:
Completely ignoring the "3d" part as this isn't really the feature I use most...
Overlay:
I'm disappointed with the video features of this card (ATI Radeon 64 VIVO). All video appears pixelated compared to my oldish TNT2. Wasn't the radeon supposed to have a vastly suprior overlay stretching? what am I missing here?
Pressing the default button on the color control dialog in the screen property decides to set my overlay brightness to the max, maybe it's because i'm accessing this data writing zoom player, but it does it when zoom player isn't loaded! BUGS!
TV Out (analog):
The TV out can't be set to 640x480! I can't select PAL! Even when set to 800x600, it doesn't cover my entire TV set, even though I set both the width and the height to the maximum.
While the TV filtering can be lessoned, it can't be disabled completely, so whatever you do, the picture isn't as sharp as on a TNT2 using a BT869 chipset (possibly the chrontel chip as well).
It's nice that you can macro the TV mode to a keyboard function, but it doesn't change the resolution, so you're stuck in a big-ass virtual desktop.
Conclusion:
Am I missing something here? Where's the great video quality? Is there a special tweaking tool I'm missing somewhere? (and I went over the display dialogs 10 times and tried everything)
And yes, I was using the latest drivers off the ATI site, which I downloaded 2 minutes before installing the card.
Overlay:
TV Out (analog):
Conclusion:
