Zoombo v1.1 is Now Available!
16:9 2.35:1 etc.
Move the Zoom and/or Set the Shutter Positions to Your Presets using a PC and the Serial Connection!
I'll see what I can do in future versions (if any) to increase the Zoom speed. Though I don't suggest this, you can change the wait_for value to speed things up.
MS Windows XP/Vista+ Supported (should also work with some Windows Versions pre XP).
MORE INFO LATER, I'M TIRED NOW!
DOWNLOAD HERE:
Download Zoombo v1-1.zip
v1.1 - 02/05/2008
+MS Vista Now Supported.
+Changed Zconfig.txt to Zconfig.cfg.
+Added Shutter Control for each PRESET (Set in Zconfig.cfg).
+Several Internal Code Optimizations.
+Fixed Xon/Xoff Flow Control Bug.
+Added 'Donate' Menu Option (Donate via PayPal for Zoomba's Development).
v1.0 - 01/28/2008
+Original Release.
SCREEN SHOTS:
This Window can be hidden at Startup
16:9 2.35:1 etc.
Originally Posted by klover /forum/post/12962520
What the hell is it?
READ POST #2!Quote:
Originally Posted by Laserfan /forum/post/12962611
It moves the Zoom controls on a Mits PJ between two positions you like i.e. 16:9 or 2.35:1.
DOWNLOAD HERE:
v1.1 - 02/05/2008
v1.0 - 01/28/2008
+Original Release.
SCREEN SHOTS:
