Status
Not open for further replies.
1 - 1 of 1 Posts
Trying to use either one button click or shortcut key that can cycle thru the "first" or "second" or "both" channel in the "MPG Audio Decoder" filter used by Zoomplayer during MPG playback?
http://12.230.111.103:8080/jacktou/w...p/mpgaudio.gif
Reason is cuz a lot of VCD use different for different lanuage, and karaoke VCD also use different channel to toggle between vocal and music only.
What I've tried:
1. I've try using the button fnAudioTrack but it didn't do anything, Infact if I check the Audio Track it shows only "Default Waveout Device".
2. The closest solution I've come to is by adding the "fnAudioDecoder" button so I can bring up the "MPG audio Decoder Properties" window (as shown above) but then I need to choose an channel and click ok, now that's 3 steps, and hard to do with just remote control.
Any Ideas???
1. I was thinking if its possible to use the FunctionParam=??? in the fnAudioDecoder button so whenever I click it'll pass a parameter to the MPG audio decoder to make it cycle thru the selected channel.
2. Any suggestion to slove this problem will ge great. Thank you
1 - 1 of 1 Posts
Status
