Status
Not open for further replies.
1 - 1 of 1 Posts
· Registered
I'm at my wits end trying to get this to work.
I did use the search function to no avail. - although I know I've seen threads just like this one in the not to distant past.... looked can't find them. Went through most other online help.
Got 2 computers exhibiting the same problems.Windows XP SP2 on Althon XP w/ 8500dv and A64 w/ 9600xt . Using the "standard" setup ZP, sonic, ffdshow, ac3filter... etc etc. I can play avi, ts, mpeg, ripped vob's fine. - no problem.
I can't play a (* DVD to same my life though. ZP locks up after 2 seconds ( shows on the bar) on dvd's in the dvd drive. And ZP locks up after 6 seconds on ripped dvd playing the IFO.
BTW - MP10 locks up about the same.
what I've done to try to remedy.
- different decoder filters - elecard, windvd (video and audio)
- different overlays - vrm9, standard mixer
- manual dvdgraph with graphedit.
- uninstalled ZP, FDDshow, filters and reinstall bare minimum
- update video drivers
- straight VGA feed instead of ATI Dongle ( which gave me macrovision errors, any fix for 720p )
I seems to me that if it happens on two systems I got some switch or fitler misplaced.
Thank you for any suggestions
1 - 1 of 1 Posts
Status
