Status
Not open for further replies.
1 - 8 of 8 Posts
In my HTPC I have installed PowerDVD XP 4.0 Deluxe, wich together with my M-Audio Delta 410 soundcard gives me 5.1 analogue channels out to feed the "5.1"-input on my receiver. But for various reasons, I would like to use ZoomPlayer as a frontend for PowerDVDs audio/video-filters.
Is there anyone here who has done this?
I've tried some DVD-graphs included in ZP, and I've tried to edit the register. No luck so far. Do I need to do my own DVD-graph, and in that case, how?
Anyone with just the slightest bit of knowledge about this. Help! Please!
/Olof
PowerDVD does not allow you to do decoding through its filter, only pass-through. You must use the program PowerDVD if you want the multichannel, analog output. This is a limit of most of the software DVD players.
Discussion Starter · #3 ·
How come Zoom Player can't use the DD/DTS-decoding capabilities of the filter, while PowerDVD can?
Is the actual decoding done in the PowerDVD software itself?
I would be very disappointed if I have to settle for PowerDVD.
/Olof
This has been answered countless times before. PowerDVD does NOT use it's own filter, it uses internal libraries instead. They basically crippled external playback support in the filters.
William -- Yes, that is what I am using currently; ZoomPlayer 2.6 with the ATI 7.6 filters and WinDVD for the audio on a Delta 410 under WinXP.
David, could you post details of what you did to setup ZP player to setup Windvd audio and ATI video.
I am using Delta 410 with analog output to 5.1 dolby audio system from AIWA.
WinDVD player works fine and puts out 5.1 audio on all channels but when I choose cinemaster (which I assume is ATI) and windvd combination from zoom player dvd setup area I only get two channels.
What specifically did you use and did you tweak anything for WinDVD to work with 410 through zoom player.
I just got started with HTPC and if the question seems simplistic I apologize in advance.
ALex
P.S. do I need to be running on XP - my current OS is win 2000
alexr -- I'm willing to bet that you did everything correctly except when in zoomplayer click options and then external and select the 6 channel option for windvd and hit apply. Let us know if that does the trick...
p.s. I'm not sure if the OS will make a difference.
1 - 8 of 8 Posts
Status
