  • Manufacturing, Myths, and Misfires with HDMI Cables. Episode 9 of the AVSForum Podcast is now live! Click here for details.
Bose 161 Bookshelf Speaker System (Black)
4.7K views 0 replies 0 participants last post by  Guest
#1 ·
Description:
Enjoy rich, full sound from music or movies with this compact pair of sleek Bose speakers. Whether placed on a desk or bookshelf or mounted on a wall for use as surround speakers, these speakers are designed to deliver balanced, spacious sound with minimal or moderate amplifier power (10 to 100 watts per channel). Automatic protection circuitry keeps the speaker drivers from being overdriven, heightening the speakers' reliability without interfering with your listening. Bose 161 speakers in black If you'll be using them in a home-theater capacity, keep in mind that they're designed to blend seamlessly with the Bose VCS-10 center-channel speaker and any Direct/Reflecting Bose speaker system. Unlike conventional speakers, which radiate sound in a single direction, these speakers use Articulated Array driver positioning and Stereo Everywhere technology to deliver balanced sound throughout your listening area. Further, Bose's two 2.5-inch proprietary Twiddler drivers per speaker move more air from their small enclosures than similarly sized conventional drivers, creating a sound you'd expect from much larger speakers. Be sure to use the proper gauge (or thickness) of wire or speaker cable for the length required to run the distance between your amplifier and your speakers. If the length is 30 feet, use a minimum of 18 gauge (.75 mm), use 16 gauge (1.5 mm) for 45 feet or 14 gauge (2 mm) for 70 feet. Supplied custom mounting brackets offer a range of placement options. What's in the Box - Left speaker, right speaker, mounting brackets, self-adhesive rubber feet, user's manual.
Details:
DetailValue
BindingElectronics
BrandBose
EAN0017817282994
FeatureVersatile speakers for music and movies
Use in bookshelf or wall-mount applications
Articulated Array® speaker design
Item Height4.17 inches
Item Length4.96 inches
Item Width10.94 inches
LabelBOSE
ManufacturerBOSE
MPN161BK
Package Height6.9 inches
Package Length24.8 inches
Package Weight8.5 pounds
Package Width8.1 inches
PackageQuantity1
PartNumber161BK
ProductGroupSpeakers
ProductTypeNameSPEAKERS
PublisherBOSE
SKU972462B
StudioBOSE
TitleBose 161 Bookshelf Speaker System (Black)
UPC017817282994
UPCList - UPCListElement017817282994
Item Weight8.5 pounds
CatalogNumberList - CatalogNumberListElement128
B00006I53A
161_Black
BSHP161sw
27027
161-0001
Model27027
ColorBlack
DepartmentElectronics
WarrantyManufacturer Limited Warranty
