Coax to RCA in-wall
2.1K views 3 replies 3 participants last post by  Jim Buza
#1 ·
Hi,
I'm putting in wire for my subwoofers. Short runs of ~6-8ft and ~12-14ft. From what I can tell, at this distance, almost any wall-rated RCA cable could work (i.e., monoprice), but since I have ample supply of coax and the equipment to terminate wondering if there's any particular reason it wouldn't be a fine idea to simply run RG59 or RG6 and then do a coax to RCA conversion in the wall plate with short cables to the woofers (probably the same wall plates that will have my left and right front speakers).
Rocks to throw at that?
Thank you!
Jim
#3 ·
Using RG6 for audio (not just video) works well. Converting from F-pin to RCA inside a wall is maybe not a good idea because the conversion can fail after a year or two and needs to be re-seated (disconnect and reconnect and you are good to go. . . for another year).
Cable companies and Sat. companies like F-pin connections because the screw on connection is solid, can't yank out, and with a little effort can even be made water tight.
  • Like
Reactions: Jim Buza
#4 ·
There are indeed wall plats (or plugs for those plates) that do the F-type to RCA. There are also compression connectors that go straight to RCA (although the ones I've found are dual-shield and the cable i'm using up is quad).
Really helpful! thank you both!
