I currently have ordered all the parts necessary to build my LCR speakers. Now, this is a slightly older design using all PE reference drivers. I knew going into this that the original shielded drivers that were spec'ed in the original design were no longer available and the consensus was that the non shielded versions would be a drop in replacement. I thought this of the tweeter as well, but apparently this is not the case.
The original tweeter was the RS28A-4 which is NLA. PE substituted the RST28A-4 as the "replacement" for it. Unknowlingly, I ordered them thinking they were the updated non shielded versions, but apparently it is just a different tweeter. And since it is an older design, no work has been done to date to verify its ability to be a drop in replacement.
At this point, my only immediate choice is to just run with it and see how it sounds. It may work great ... or it may not. But I have no way of knowing without listening to it, because my crossover knowledge is dangerous at best. I understand the components, what they do, and how their values change in relation to series or parallel circuits. I understand all the basics of 6,12,18 and 24 db slopes and Lpads but after that, I'm all out of tricks.
So I guess what I'm getting at is, if it doesn't sound right, what is my next step? How does one go about designing a crossover? Does it start with an electronic simulation in a spreadsheet and a predicted response or are driver measurements the first step? Or do the driver measurements need to be done in the baffle since I already know the baffle width. And if so, how to do them?
Or would somebody really familiar with crossover design be able to just confirm that they are drop ins merely due to their experience with crossover design and topology?
I don't mind putting in the work and learning, and I've always been interested in all the intricacies of crossover design as well as enclosure design, but I'm not sure where to start.
I apologize for the long post, but wanted to try to explain my conundrum completely as well as my willingness to also work/learn if necessary and looking for any feedback and/or direction i can get.
