  • Everything You Wanted to Know About HDMI Cables. Ep. 7 of the AVSForum Podcast is now live. Click here for details.
DIY paint on existing projector screen?
1 reading
20K views 11 replies 3 participants last post by  MississippiMan
#1 ·
Hi all,
Apologies if this is a silly question, I'm quite new to this whole DIY scene.
I am currently renting and so can't really hang up a ready-made screen on the wall, but what I did instead was buy a 92inch Optoma pull up screen, specifically the DP-9092MWL, which has a gain of 1.0. Because my Benq W7000 doesn't do deep blacks, I was thinking I could do with a high contrast screen and maybe something like a gain of 0.8 to get deeper blacks and bump up the contrast.
My question is though, can I directly apply the DIY paint to the Optoma screen without adverse results? That would be the easiest way I guess to get the contrast ratio up without spending a fortune.
Thank you for your kind replies!
#2 ·
Originally Posted by fragfeaster777  /t/1501879/diy-paint-on-existing-projector-screen#post_23998229
Hi all,
Yes....painting onto a Mfg screen is very "do-able".
Read this Thread:
http://www.avsforum.com/t/1432177/painting-onto-a-106-tab-tensioned-screen-with-silver-fire-v2-5-4-0
#5 ·
Tbh I just did a quick flit through. I admire what you have done but a lot of time and effort involved. All I'm saying is why not just put the extra cost to a better gray screen in the first place?
I have made a roll up DIY screen myself in the past and painted it gray. It lasted a couple years but then the screen and paint started to crack because of repeatedly rolling and dropping the screen. Maybe the material and paint weren't good enough and there's my point. Is it worth modifying a cheap screen with expensive paint, will it last, would the cost saving and benefit be enough to outweigh buying a decent gray screen in the first place?
#6 ·
Hi,
Thank you for your replies. MississippiMan that's a great project, the photos look great and i'm sure they dont even do the actual thing justice. You should be proud of that project.
Ash, I would buy a gray screen but as I mentioned I am renting and cant affix stuff to the wall, so im relying on something that can be pulled upwards, which is what I have now.
I will see if the paint you used MississippiMan is available in the UK. Then comes the hard bit...
#7 ·
Originally Posted by fragfeaster777  /t/1501879/diy-paint-on-existing-projector-screen#post_24007763
Hi,
I think you misunderstand me. Gray screens are available in pull up/pull down fashion just the same as white screens.
#9 ·
Hi,
It can be assembled with local items or acquired via Internet sources, and/or arrangements can be made to provide you with the components you lack.
#10 ·
Awesome advice, thank you!
Ash I had a quick look at pull up gray screens but unfortunately none are ready made in the UK, and I can maybe give a few shops a call but they would easily charge in excess of £250 ($400), not really worth it I guess.
MississippiMan your method looks truly like a work of art, and I will try to replicate it though fear I will only get there half way. I was hoping to do the painting next weekend as thats the only weekend for the foreseeable future where I will have multiple uninterrupted hours, so I think that means that ordering the Silver Fire paint supplies from the US is a no go as don't think they will arrive on time. Furthermore I read (from you I believe) that you definitely need to use a spraying system, which in a flat that's not mine makes me really, really nervous!
What I am thinking of doing instead is maybe going down the latest Black Widow route and using a roller. The room I am in has white walls so ambient light is definitely an issue, making me think that a gain of 0.8 is what is needed. There was a post on the HTS forum where they advised a UK user which paints to use... so I may bug them with my questions even though it's clear your knowledge is much superior. Unless there's some way I can figure out which are the UK paint equivalents? Sorry I have no idea about paints!
Let me know what you think or if you have anymore tips... I truly appreicate your help!
#12 ·
Originally Posted by fragfeaster777  /t/1501879/diy-paint-on-existing-projector-screen#post_24011150
Fur'goodness sake, don't repeat the highlighted part above "over there" or all hell will break loose!
BW should work OK...it certainly is under 1.0 gain. You might have issues with some Graininess though.......especially if you roll it on. Good Luck!
