Yes.
I bought one of the close-out NEC 4000Q's from AV Science. With the signal quadrupling and a subtle tweaking of the sharpness and detail settings, DSS looks quite good. Last night's The Sopranos was excellent.
But wait, there's more! I was watching on my TiVo, not recorded at the highest quality setting. And here's something that is amazing me. Those who have PVR's know that in certain kinds of scenes you can easily see the square MPG compression artifacts: dissolves, fire, explosions, etc.
Since using the 4000Q on my FPTV, I haven't seen ANY of those artifacts. I can only assume that the NEC is comparing multiple frames and correcting the problem. Frankly, I couldn't believe my eyes when I first noticed this.
I'm slowly finding the ways to set the many adjustments to max out the image quality with my FPTV. For instance, tonight I discovered you need to set motion compensation to the minimum value, otherwise you get judder.
Still tweaking...
[This message has been edited by boblinds (edited 08-14-2001).]
