I am using the Buffalo AirStation Turbo G High Power Wireless Ethernet Converter. Works great. I use it for my xbox 360, tivo series 3, and toshiba HD-XA2. If you enable DHCP on your router, you don't have to really (or shouldn't have to) configure anything on the player, you just plug it into one of the ports on the bridge. The configuration of the bridge is simple too. The one i have has a web interface. When you go in you just have to put in the SID for the wireless network and password, etc. and you're good to go. This way is more economical that getting wireless adapters for everything which was going to be my initial route.
