What is the gamut coverage of some of the best Plasma's? Like Pioneer, Panasonic & others.
% of 709 & P3 & 2020
Missed CEDIA? We Got You Covered! Episode 8 of the AVSForum Podcast is now live. Click here for details.
Interesting question. I don't really know, but I think the Panasonic ZT60 and VT60 specs claimed 98% of DCI (P3).What is the gamut coverage of some of the best Plasma's? Like Pioneer, Panasonic & others.
There is. Downscaled to 1080p UHD content with higher color gamut.Rec 709 100% or beyond if you oversaturate..
DCI-P3 has more saturated Greens and Reds but there is no content for a Plasma TV with that color space?
I have a UHD player and quite a few disks. There is definitely downconversion from HDR to SDR -- but not for colorspace. Now, it's true that the plasma likely can't display it fully and accurately, but there are definitely colors I'm seeing that I don't get with regular rec. 709 1080p blu-rays.No,
colors get converted to SDR
I haven an UHD Player. The down conversion to 1080p and SDR color space was implemented from the start.
You really need a 4k display that will display P3 color space.
Who is confusing it? rec. 2020 is a bigger/wider color space than P3.you are confusing rec 2100/2020 for p3.
It's the formula ColourSpace uses to calculate gamut coverage that causes the disparity between what one would expect as indicated by a 2D graph and the gamut coverage percentage.So according to colourspace my kuro will hit 99% rec 709 and a pathetic 65% p3 in RGB full 10 bit so not accurate at all. I ripped my copy of cat people in 4k uhd and played it with no downconversion and it just looks dim. but you can watch it. looks crummy. i didn't mess with any of the kuro settings just the same calibration i did 6-7 months ago. My samsung pc monitor which is my daily driver will show 78% p3 in SDR mode so much better than the old plasma.
like you said, if you go in and tweak the brightness and saturation of these panels you could get better numbers i think.
There probably was 10bit content, but not video.No 10 bit physical media was available either, but 9th gen kuros are 10 bit native
