I recently "upgraded" my amplifier from Audiolab 6000A to the Lyngdorf TDAI-1120 for dual use A) as 2.2 channel setup for music and B) as HT bypass power amplifier for the Denon AVC-X3700H. The problem i'm having i believe is a ground loop issue which i've spent hours trying to solve in the last couple of days and not really made progress. The Lyngdorf is being used as a power amp for a few different sources but there's one in particular where the issue is really bad; my gaming PC! When the GPU is under load the amount of noise coming from all channels is really loud, previously when i used the Audiolab for this purpose there was only very minor noise coming from the rear left speaker as it's right next to the PC. The PC is at the opposite end of the room to the AVR + Amp so plugged into a different socket - all 3 devices are connected to surge protected extension units. I've tried running an 8 gauge speaker wire between the the AVR + Amp grounding points which did help reduce some static noise but still very audible. Changing the volume has not effect. Input sensitivity on the Lyngdorf is 0db - if i increase this then the problem worsens. The Denon has a 2 prong power socket and the Lyngdorf has a 3 prong power socket. I've ordered an RCA ground loop isolator and the IFI GND defender which arrive tomorrow and i'm praying it'll fix the issue but failing that i'm wondering if any of the forums learned members can share other ideas as i'm at my wit's end and don't want to have to return the Lyngdorf and go back to the Audiolab as i really like what RoomPerfect has done for my music listening experience
