OK, so after fiddling with Iron Man for hours I need some help. The only English soundtrack I can play is 2 channel. Looking to get 5.1 sound
My setup:
Gigabyte GA-P35-DS3L (currently using the SPDIF digital coax output of this board to my receiver)
Nvidia 9800 GX2 with HDMI video out to my projector
Arcsoft TMT, playing ISO files from my Unraid server via MyMovies in Vista
Sony SDR-DG1000 Receiver
All my other Blu-Ray and HD-DVD ISO's play 5.1 sound just fine. I found in the menu of the Iron Man disk for Audio settings only three choices: English Dolby TrueHD, French Dolby 5.1, Spanish Dolby 5.1. My Sony receiver cannot decode True HD (I hope to upgrade soon, but it doesn't help me now). If I select the French Dolby 5.1, as you'd expect the 5.1 works fine. But if I select the True HD English, it goes right back to 2 channel.
Other things I've tried:
1. If I put the original disk in my PS3, everything works great, my receiver outputs 5.1 Dolby, so this tends to suggest for me it may be the software (TMT) that can't support the TrueHD? If not, shouldn't TMT at least convert the soundtrack so that can be interpreted as a more standard 5.1 Dolby track for receivers without TrueHD capability?
2. I bought a dedicated 7.1 Siig Soundcard with SPDIF digital coax output. I installed this, but same story, just 2 channel.
3. I also have the internal MOBO SPDIF cable plugging into the 9800 GX2 card, and it will transmit audio through the HDMI cable. So I plugged the HDMI through my receiver and then output video to my projector from the receiver. Same story, only 2 channel.
Any tips? Seems to me like it's TMT, but digging through the TMT forums and AVS forums, seems like others have got it to work with standard 5.1.
My setup:
