Somewhat unique question looking for some feedback from fellow members:
Background / equipment:
Denon X3500H
Running 5.2.0 with no intent for atmos in the near future
Not a gamer….heck I just got a 4k tv last year lol.
Minidsp 2x4HD for subwoofer management
Using an external amplifier for all channels.
My issue:
I feel I’ve outgrown the Denon with regard to speaker calibrations/equalization.
I’m familiar enough with REW and sub EQ management, that Audyssey just kind of frustrates me at this point (the overall process / effort of calibration, hoping the end product turns out good after all the sweeps, the issues such as distance/timing bug, etc etc).
Too much goes on behind the scenes, and just feels like chasing your tail / relying on Audyssey or Denon to output what you hope you’ll like.
I’ve got the multieq app, and it’s decent but again I’ve out grown it compared to REW’s offerings.
(Ie- way more difficult than it needs to be to try editing the curve, then reuploading to the AVR, etc)
Next logical thought would maybe be MQX….but my worry with it is:
So, what I’m wondering:
What’s out there that would fit my needs?
I‘m basically seeking a processor that would allow me to somewhat easily manually edit my EQ as desired, without another steep learning curve.
I know there’s DIRAC, and it may be a good option, but at face value it seems like another automated calibration rabbit hole of education to learn the system to suit the needs.
A few thoughts I had were:
1) maybe the Yamaha A4A or older 1080, since I believe it has a manual PEQ.
2) Keep the x3500 and try
a) using Denon’s basic GEQ (limited but better than nothing). Saw OCA had some good videos on how to optimize outside of Denon/Audyssey.
b) Buy a second 2x4HD and connect my LCR and manage with 2x4HD plug in (one Minidsp for the L and R, the other for the center only)
c) buy a multichannel Minidsp (Expensive and hard to find)
3) Get a new 3700
-I would also add MQX, because at least it’s a newer receiver and I could sell my x3500
-MQX would allow me to import REW filters
-would give a few features my 3500 doesn’t have, such as multiple presets
4) Look into Dirac-equipped receivers, because it’s not Audyssey lol.
For the Dirac option:
I’ve looked into the Arcam AVR10, Anthem MRX540, Nad T758, Integra/Onkyo/Pioneer units, and new X3800.
Quite frankly all of the options seem to have their own pros/cons/bugs.
Anthem = fan noise, Arcam = bugs (at release), NAD = all sorts of issues lol, Onkyo Group = owned by VOXX, Denon = very expensive
Then there’s ASR’s review of the receivers, which may be a consideration if I’m using the preamp outs.
So, Any thoughts on the above? Anything I’m perhaps missing? Or anything in my assumptions that I have wrong (ie - a Minidsp in the chain may not work well)
FYI I’m not opposed to refurb or b-stock, but would like a good return policy if things don’t go as planned lol.
Denon X3500H
My issue:
- spending $200 on the product locked to the receiver that’s already 4+ years old
- I have a Mac…..not a dealbreaker cause I have bootcamp, but I prefer to run REW on the Mac vs having to switch it over to PC application….which I think would be required to also run at same time of MQX to ensure everything looks good? (in other words, I don’t want to have to switch between running MQX in PC and then sweeping in REW in Mac)
- Benefit of MQX is that it apparently allows import of REW filters, so that sounds appealing
3) Get a new 3700
